Headstock decals http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=46652 |
Author: | cablepuller1 [ Thu Nov 12, 2015 6:16 am ] |
Post subject: | Headstock decals |
Hi Dont know if anyone uses decals.. had some with my name done (not cablepuller ) ![]() Can see the decal clearly after oiling or spaying nitro... it seems to be more about the underside of the decal going a bit misty/opaque against the dark ebony plate rather than the edges showing. Is this normal as ive only done 4-5 coats over top of decal but stopped as its still rubbish looking Not happy to put on guitar until I know Thanks |
Author: | Greg Maxwell [ Thu Nov 12, 2015 9:26 am ] |
Post subject: | Re: Headstock decals |
I inlay my guitar pegheads with pearl, but I have done some decal work for customers. Did you finish the Ebony before applying the decal? I think part of getting an invisible decal is preparation. Seal and topcoat the Ebony first, allow to cure, wet sand and buff to gloss, and then apply the decal. Build more clear coats and then wet sand and buff again. I've only used this process on Maple but the results are excellent. I don't think you'll be able to use an oil finish with decals. |
Author: | Shaw [ Thu Nov 12, 2015 6:54 pm ] |
Are we talking waterslide labels? If so for it to blend in well there needs to be a finish base. Sent from my SGH-T599 using Tapatalk |
Author: | cablepuller1 [ Fri Nov 13, 2015 1:13 am ] |
Shaw wrote: Are we talking waterslide labels? If so for it to blend in well there needs to be a finish base. Sent from my SGH-T599 using Tapatalk Yes Shaw waterslide... the practice runs i did didnt have a great finish under them,more of a smooth base coat Cheers |
